Re: moving H wheels in
Posted by captaink on October 05, 2004 at 08:59:46 from (66.115.214.56):
In Reply to: moving H wheels in posted by packrat on October 05, 2004 at 08:18:29:
I’m going to presume you have already applied some form of penetrating oil, or PB blaster to the bolts. If not use some. In addition, vibration can do a lot to win the war against rust. If you have an impact tool of some sort, use it to create a vibration in the bolts. If you have an air hammer it will work too. If you don’t, then use a punch or drift and hammer the tops of the bolts and the sides of the castings again the object here is to create a vibration. All else fails get the flame wrench out…
Post a Followup
Subject:
