Stuck steering wheel hub on M
Posted by David in UT on October 05, 2004 at 09:38:05 from (68.165.29.122):
third party image
Hi all,
I'm working on a '40 M, and I was just able to get the definitely-non-original steering wheel off. It looked like something you'd put on a 60's muscle car and it had been welded onto the shaft (!). Now that I've got it clear, I'm left with the steering shaft and what looks like a keyed hub or spacer on the end of it. The new steering wheel won't fit on the shaft without removing (or cutting down) the spacer, so I need to get it off. Is it just press fit onto the shaft? Any secrets or tricks? Thanks,
- David
Post a Followup
Subject:
