Re: 706 rearend weight / strength
Posted by K.B.-826 on October 06, 2004 at 18:44:47 from (209.163.43.4):
In Reply to: 706 rearend weight / strength posted by The Farmall on October 06, 2004 at 08:29:57:
As the tractors got progressivly bigger, so did the rear end. For example, an 806 has heavier axles than a 7, probably bigger bull gears as well. A 1206 would definetly have heavier axles and bull gears. As far as I know, most if not all of the beefing up was done to the final drives, that is, the bull pinion/bearings, bull gear, and axle/bearings. Most of the parts in the actual range transmission case will interchange. A 706 ring gear and pinion shaft is the same as what many of the bigger ones used.
Post a Followup
Subject:
