Re: Super M Power Steering?
Posted by boydg on October 08, 2004 at 07:55:39 from (208.186.57.65):
In Reply to: Super M Power Steering? posted by John Kitsmiller on October 08, 2004 at 07:29:12:
You have a Charlyn power steering on your M. The sleeve does not look familar to me, but there should be a roll pin and not a bolt in the shaft. They can be purchased at any good hardware store.When you put the pin in it is a good idea to wire it in. Best not to use a bolt. For safty sake you can also put a smaller roll pin in side the larger one. Hope this helps. Boyd
Post a Followup
Subject:
