Re: IH 656 or 666?
Posted by Hugh MacKay on October 08, 2004 at 19:45:51 from (64.228.11.136):
In Reply to: IH 656 or 666? posted by K.W. on October 08, 2004 at 03:22:50:
K.W.: Probably the single biggest improvment in the 666 over the 656 in the diesels was the fact with 666 you are rid of the glow plugs.
My opinion none of the IH 6 cylinder gassers were much. I lived in much colder climate than Iowa, and both my 560 and 656 were diesel. Put enough battery in there and add a circulating block heater, they are good for -40F. I don't plug my diesels in for starting, it's done to reduce engine wear, thus they will be plugged in any temp below 40F.
Post a Followup
Subject:
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
