Re: H engine idle
Posted by riverbend on October 09, 2004 at 16:10:13 from (208.160.33.232):
In Reply to: H engine idle posted by ernz on October 09, 2004 at 16:02:31:
A couple things to try - Does the air adjustment screw have any effect if you turn it when the motor is running at low rpm ? If you remove the linkage between the governor and the carburator, and close the throttle by hand, does it idle down ? Is the governor or governor linkage sloppy ?
Post a Followup
Subject:
