Re: 966 won't move
Posted by K.B.-826 on October 10, 2004 at 20:19:12 from (209.163.43.102):
In Reply to: Re: 966 won't move posted by Frank F on October 10, 2004 at 06:32:34:
Frank, It concerns me that you can shift the range transmission with the clutch pedal out. Normally, you can shift the Speed transmission with the tractor not moving and the clutch pedal out since it is a sliding-gear trasmission, but the Range transmssion is a collar-shift and should grind like crazy and be impossible to shift with the clutch pedal up. Sounds like your MCV, MCV pump, and TA are going to need some work. Get someone with the gauges, a Flow-Rater, and the manual to check it out.
Post a Followup
Subject:
