Re: IH wide front adjustment
Posted by Allan in NE on October 13, 2004 at 03:24:28 from (148.78.243.24):
In Reply to: IH wide front adjustment posted by JD Jim A on October 12, 2004 at 19:58:56:
Hi Jim,
Those front ends are a stinker even if you move 'em all the time and I don't think it matters which tractor you tackle; they are all nasty.
What I used to do, is to first loosen the cinch bolts, soak 'em down good with penetrating oil for a couple of days; maybe even a week if you have the time.
Then, the key is to get them to move "out" first. I'd lay a handyman jack on it's side and jack that big tube out against itself. (hope that makes sense). And then use a little hydraulic jack and some blocking on those tie rods in the same manner.
Also, take a big bar and get the thing to rotate. After you get it to move any at all, the fight is just about won.
Pull each side clear outta the front end, clean the tube and tie rods up, oil 'em a little and then they will just "fall" back in there.
Good luck,
Allan
Post a Followup
Subject:
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
