Re: International Model M Grain Drill
Posted by riverbend on October 13, 2004 at 19:15:25 from (208.160.34.17):
In Reply to: International Model M Grain Drill posted by rwlmak on October 12, 2004 at 17:10:02:
Lets try again -
If you have an MF, look at abebooks(dot)com and search for mccormick grain drills. I have a manual for an MF. It shows the seeding rate adjusted with a small gear that is set against a cone shaped cluster of (drive, I suppose) gears. That manual has a chart for setting seeding rates, etc.
Post a Followup
Subject:
