Re: Need help with brakes on my 806!
Posted by ChadS on October 17, 2004 at 08:53:12 from (66.228.96.214):
In Reply to: Need help with brakes on my 806! posted by 806 D on October 16, 2004 at 19:59:19:
Our 856 had the same problem, there is a seal in the brake that can either leak internally, or leak outside the brake housing, fixed the seal and still did it,, found a pressure relief valve in the master cyl, an oring was split and was bypassing the full fluid pressure to the brake cyl. Hope this helps, ChadS
Post a Followup
Subject:
