Re: 50 M Carb
Posted by Dave in CT on October 17, 2004 at 10:11:50 from (64.252.220.230):
In Reply to: 50 M Carb posted by Adam Whitson on October 16, 2004 at 17:44:56:
If it's the the shorter brass tube for the idle circuit - the one that is positioned 90 degrees from the flat surface of the body of the carb - I would clean out the passages but not try to remove it. I've heard from a few sources that it's easy to mess up both the tube and the threads it screws into so, if you can get the passages clean, that should be enough. My 2 cents.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
