Re: 2 Point Prolbem
Posted by Joe Evans on October 20, 2004 at 07:17:25 from (209.41.233.116):
In Reply to: 2 Point Prolbem posted by Dann on October 19, 2004 at 19:56:38:
Get an I&T manual for that series tractor. It'll cover the 460, 560, 606, 2606.
You just can't sling the new feedback linkage on the tractor and expect it to do its job. There is a series of critical adjustments that have to be done, and the I&T manual does an excellent job of stepping you through this.
If I remember correctly, there's no way the small arm will spin 360 deg freely if everything inside is kosher. Check to see if that arm is pinned to the control axle. The axle is what enters the Tel-A-Depth spool body. The pin may be gone. (I wish I had my manual here with me!)
If the arm and its axle connection are OK, then it sounds like there is a problem with the set of differential gears that reside inside the Tel-A-Depth vavle body. These are easy to access and inspect. Sometimes the gears get stripped and/or they may lose the pins that connect them to their axles. This differential gear set tells the spool to shut off the oil flow to the fast hitch cylinder when you've selected a fast hitch height.
It sounds like you really have a problem with the gears. Your movement of the Tel-A-Depth control lever is transmitted to the Tel-A-Depth spool thru this gear set, too. It appears the gears have problem and are only letting the control lever to move the spool in one direction only.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
