Re: Farmall M Electrical System
Posted by Hayfarmer on October 21, 2004 at 21:42:46 from (66.243.232.213):
In Reply to: Farmall M Electrical System posted by Old Iron Mike on October 21, 2004 at 13:24:05:
Some more advantages, 12 volt lights are easy to find, 6 volt ones aren't. If you ever run equipment lights off tractor system, like I do with baler, most are 12 volt. Generally when you go to 12 volt you also change to an alternator and they put out a lot more juice if you do run lots of lights. Folks say the 6 volt system will work just as good as 12 volt if kept up right, heavy battery cables and all. That may be true but with a long run, like from a battery under the seat to the starter, you need a really heavy cable with 6 volts, not so with 12. I like the way my SMTA starts quickly with the 12 volts. My feeling is that if you are after originality all the way stay with 6 volts, if it is a "user" the 12 volt setup works better. If you do change over you may want to keep the 6 volt parts anyway incase you sell it some day or 6 volt systems come back into use.
Post a Followup
Subject:
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
