Re: Farmall M Questions...
Posted by Hugh MacKay on October 22, 2004 at 02:39:41 from (216.208.58.119):
In Reply to: Farmall M Questions... posted by A Billheimer on October 22, 2004 at 00:39:13:
A Billheimer: How is the clutch adjustment? I forget the exact adjustment but you should have about 1" give or take a bit between pedal arm and deck plate of transmission. Substancially more than that could cause it not to completely release. I your tractor has not seen a lot of use lately, sticking or rust could be problem. Three areas could be problem pilot bearing, release bearing or clutch disc not moving freely on shaft. Do you hear any noise when clutch is depressed, either in gear or out? Release bearing could make a noise any time clutch is depressed, whereas pilot bearing will only make a noise if transmission shaft is stopped as in gear. It is unlikely clutch disc sticking would make any noise. My recomendation would be check clutch adjustment then use the tractor. Pull some good heavy loads. Do a bit of foreward and backing, generally a lot of shifting gears. If you stop to shift gears, will transmission start turning again as you go through neutral? Try letting tractor run with clutch depressed and in gear for 20 min. Hooking it to a tree may be good idea during this 20 min run, most importantly make sure clutch pedal is anchored down well. Your not going to sit 20 min with foot on clutch pedal. This is the cheap fix, you still may have to split tractor for repairs in the end.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
