Re: I need your help on a Super C, please
Posted by gauger on October 22, 2004 at 05:59:15 from (12.155.240.196):
In Reply to: I need your help on a Super C, please posted by genep on October 21, 2004 at 14:50:21:
I would replace the crank gear too as long as you're in there. It will be worn. I just replaced both on a C-113 rebuild and man did it restore the proper backlash. Expensive but worth it. Also, changing that cam gear will be much easier using an arbor press with the shaft out of the tractor.
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
