Re: hydraulic level on a 240 w/ loader
Posted by K.B.-826 on October 22, 2004 at 18:05:52 from (209.163.30.68):
In Reply to: hydraulic level on a 240 w/ loader posted by Dave D on October 22, 2004 at 07:21:58:
Dave, sounds like that "radiator-type hose" is your suction hose out of the reservior, which must be the frame of the loader. Try unscrewing that pipe plug again, and see if it's a dipstick. There shouldn't be any real pressure that could force hot fluid out at you, but just to be safe, check it after the tractor has sat for several hours, and move the controls all the way both ways with the engine off to relieve any pressure in the system. Look around the bottom of the frame for a drain plug. Standard hydraulic hoses will be fine, I doubt that system makes any more than 2000 psi. One trick I use when a hydraulic hose fitting starts rounding off with an open-ended wrench- cut the hose off with a hacksaw and use a six-point socket to remove the fitting. Make sure to always use a back-up wrench to hold the line or fitting that the fitting you are removing screws into, to avoid twisting things off. While you're at it, change the tractor's rear end/hydraulic system too. There's one drain plug underneath, and three drain plugs right in a row on one side of the middle of the tractor, right beneath the hydraulic valve block. There's a fill plug behind the seat, dump five gallons in there, there's another fill plug on the left side of the top of the trans case, right behind the clutch housing, fill that level full. Use Case-IH Hy-Tran or another name-brand hydraulic fluid.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
