Re: M, Carb, Float Needed
Posted by Terryc on October 23, 2004 at 15:35:57 from (69.60.227.62):
In Reply to: M, Carb, Float Needed posted by Adam Whitson on October 20, 2004 at 19:45:29:
If you dont find a replacement most flowts can be fixed, usually just a pinhole, dunk it in a can of water for a min or so, remove from water, heat ir with a propane torch, the hole will whistle just like a tea kettle, then repair with solder, water will be boiled out when you heat the float... takes some patience and a steady soldering hand but works great. Good Luck
Post a Followup
Subject:
