Re: splitting a 1256
Posted by Aces on October 23, 2004 at 18:09:28 from (65.54.98.145):
In Reply to: splitting a 1256 posted by bones on October 23, 2004 at 17:39:42:
Bones the TA housing and rear end oil all the same but if you drain from the plug under the TA that should do it. I always took the fuel tank and steering column off because will have to split at the engine then take the ta off the rear end. After you have good stands and remove the screws it will slide a part. Don't forget the 2 1/2" hex cap screws that go into the back of the block right blow the tank. When you go back together at the first split put a little spacer under the heal of the main clutch fingers to compress the pressure plate then put the pressure plate on the PTO drive shaft and the clutch drive disc on the TA input shaft put the tractor back together then bolt the clutch to the flywheel through the inspection hole under the clutch. If you put the clutch on the flywheel then put the tractor back together, trying to aline the splines you could push the TA input shaft back into the TA then you got a bad TA.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
