Re: New 1256 turbo (new to me!)
Posted by K.B.-826 on October 25, 2004 at 19:22:42 from (209.163.30.30):
In Reply to: New 1256 turbo (new to me!) posted by ButchWI on October 25, 2004 at 02:54:43:
It's a '69 model, a very late one. The S means it has a TA, the Y means a 12 gallon per minute hitch pump, as do 99% of them. Could not find the AA. The clutch is the heavy-duty 14" with 15 springs, and is a pain if you do not have the hydraulic assist option. The reason it feels like it is engaged or disengaged is because your TA dump valve is out of adjustment, causing the hydraulic clutch pack in the TA to re-engage after the main clutch. Get yourself an I&T manual and go through the entire clutch, TA, transmission brake, and shift linkage adjustment, and it will be a totally different tractor. The best place for the IH logo will be a junkyard, although most of them are broken. Check to see if you can get it from Case-IH, and let me know if you can. 856, 1456, and 1026 use the same logo.
Post a Followup
Subject:
