Re: grinding gears
Posted by steveormary on October 26, 2004 at 10:34:19 from (216.31.92.119):
In Reply to: Re: grinding gears posted by CNKS on October 25, 2004 at 19:11:27:
If your tractor has TA pull TA lever back and start out or shift up to gear you want to travel in and then move TA lever ahead. With some practice and the good advice from this board you will do just fine.
steveormary
Post a Followup
Subject:
