Re: IH 3414 B414 Injection Pump timing
Posted by JB2 on October 30, 2004 at 20:46:15 from (24.157.143.220):
In Reply to: IH 3414 B414 Injection Pump timing posted by Franklin Scott on October 30, 2004 at 20:13:02:
Hi, if my memory is correct and this is from 35 years ago, the drive shaft for the injection pump has a key in the shaft that goes into the timing gear. So there is no way for it to be out of time by 180 degrees unless the key was not put in the shaft. There should be a couple of lines stamped in the timing gear cover by the studs that hold the injection pump on. If the previous owner had scratched a marked for the exact location of the pump before removal it could have been re-installed to the original position and the timing should have been good. If you can find the two stamped marks on the timing cover set the mark on the pump to half way between as a starting point. Are you positive you have all the air out of the injector lines ? When you loosen the lines to the injectors is this fuel squirting out every time the engine is cranked? If injector pump is timed to fast it will kick back on the starter and if it is to slow it will be hard to start and smoke a lot and will blow white smoke out the exhaust when attempting to start. Good luck JB2
Home
| Forums
Today's Featured Article -
Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
