Re: Magneto cut-off switch
Posted by Geoff NY on October 31, 2004 at 16:11:36 from (24.185.226.138):
In Reply to: Magneto cut-off switch posted by WD-9 on October 31, 2004 at 06:19:58:
You say your 9 doesn"t have a mag, so I have to assume it now has a distributer. If so you should have a manifold with a contact switch for a distributer. In either case the switch stopped power from going to the spark plugs when in the diesel mode. If you want to leave it alone, just make sure you turn your key switch (or whatever sends power to your distributer) when your in the diesel mode. No real need to plug the hole. Geoff
Post a Followup
Subject:
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
