Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: Re: Ok...got the brake cover off and here is what I found -
Posted by Farmer Bob on November 17, 1999 at 21:20:41 from (207.227.187.183):
In Reply to: Re: Re: Re: Re: Re: Re: Ok...got the brake cover off and here is what I found - posted by Farmall Newbie on November 17, 1999 at 21:09:53:
Farmall, The cork gasket is right behind the large heavy washer that the cap screw went through. It may have come off with the washer and you didn't see it. It should show signs of imprint of the end of bull pinion shaft. I used a gear puller (with reversible fingurs)to get my seals out but you need one that's small enough to get in behind the seal to grab the inside rim of the seal(s). BTW where are you? I'll be back on tomorrow eve to check your progress. Post your results please. FB
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Ok...got the brake cover off and here is what I found -
