Re: Does the color of exhaust manifold matter?
Posted by Bob M on November 01, 2004 at 09:35:13 from (165.170.128.65):
In Reply to: Does the color of exhaust manifold matter? posted by Brian in NY on November 01, 2004 at 09:18:14:
Brian - H manifolds are all made of cast iron. Any "color" you see on 'em new is paint. And unless it's a special high temperature paint the first time you work the tractor hard the paint burns off. The manifold will then shortly turn rust-colored.
Can't speak for the origin of Steel Wheel Ranch's manifolds. However purchased one a few years ago from Tisco. Though it was made in China and doesn't appear exactly as the original (it's missing the small plugged opening in the intake riser) it fits, works and sounds fine.
Post a Followup
Subject:
