Re: Pulling the flywheel off the crank
Posted by El Toro on November 03, 2004 at 05:41:10 from (205.188.117.13):
In Reply to: Pulling the flywheel off the crank posted by Alberta farmall A on November 02, 2004 at 11:17:21:
If you're trying to pull the crankshaft pulley
my IH manual shows a 3-leg puller being used. Heat the hub of the pulley while tightening the puller. The flywheel is on the other end of the engine that has your clutch bolted to it. Hal
Post a Followup
Subject:
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
