Re: Manifold
Posted by Brian in NY on November 03, 2004 at 05:42:30 from (24.97.78.198):
In Reply to: Manifold posted by Old Iron Mike on November 02, 2004 at 07:44:00:
Have you tried turning the nuts yet? I have found that if you let the tractor run for 2 or 3 minutes, then go at it lots of times they come off nice and easy. Just changed out my first H manifold and this was the case. Was smooooth sailing. If they are stubborn....a soak with PB Blaster coupled with some light taps on the nuts very well might get you headed in the right direction...just my $.02.
Post a Followup
Subject:
