Farmall Tractors Discussion Board
Super A brake job
Posted by steve on November 18, 1999 at 08:39:17 from (12.10.147.50):
I need to do the brakes on my '49 Super A. What is the best way to remove the axle housing?
Should I jack up the tractor, and remove
the whole wheel and axle assembly together, or
jack the tractor, remove the wheel, and then try
to pull the axle housing off? I assume the housing weighs 100lbs+, so I'll get help.
There is no convenient way to grab onto the axle housing, it appears.
Also, I have the I&T manual, but are there any small parts that might fall out upon removing the axle housing? I don't want to create more problems than I'm trying to solve.
Other than replacing the seals and brake bands, is there any other maintenance I should do while it's
apart? I'll remove the bull gear covers, and clean out all the oil and sludge in them, while
the axle housing is off.
Thanks!
Steve
Post a Followup
: Re: Super A brake job
