Farmall Tractors Discussion Board
Re: Super A brake job
Posted by John C. on November 19, 1999 at 07:14:18 from (12.13.248.14):
In Reply to: Super A brake job posted by steve on November 18, 1999 at 08:39:17:
The other gentlemen have given you some great advice. I recently did the brakes and axle seals on my '47 B. I jacked the tractor up from the axle housing, removed the wheel, and lowered the tractor onto a jackstand under the differential. I used an engine hoist to remove the axle housing/final drive on one side, and used a large transmission jack to remove the other one. I liked using the transmission jack better, because it was easier to get the housing and axle aligned when re-installing. Hope this helps.
Post a Followup
: Re: Re: Super A brake job
