Dummy Needs Advice Again
Posted by Allan in NE on November 03, 2004 at 18:20:00 from (148.78.243.26):
Hi Red Guys,
Need some advice again.
I'm in the process of building a set of truss rods to strengthen the underbelly of my H for loader use.
As a first step in the process, I opened the cover to the belly pump, pulled the pump drive down outta there and cinched down the torque tube attaching bolts good and tight.
Now while I was inside the cavity, I noticed a small fluid leak at the drive shaft coming from the rear end that originally drives the belly pump in these things.
Question is: Can those seals be changed from the pump drive cavity side, or do I have to lift the lid on 'er to get at that seal?
Thanks,
Allan
Post a Followup
Subject:
