Re: Dummy Needs Advice Again
Posted by captaink on November 04, 2004 at 08:11:55 from (66.115.214.56):
In Reply to: Dummy Needs Advice Again posted by Allan in NE on November 03, 2004 at 18:20:00:
If it is like the M there may have originally been a wider seal than you will be getting as a replacement. Sometimes when I run across this situation I have installed two seals hoping that one of them will be riding on a new sealing surface the pump drive. Check for a groove worn in it, there are "speedy sleeves" available that will restore surfaces for oil seals to run on which is another option. My nickel's worth.
Post a Followup
Subject:
