Re: BN cooling problems - Part II
Posted by CNKS on November 03, 2004 at 19:04:14 from (207.178.96.212):
In Reply to: BN cooling problems - Part II posted by ffolkes on November 03, 2004 at 18:14:02:
As posted by several in your original post, you have a clogged radiator and/or a clogged block. There's nothing left, unless you happen to have a cracked block or head that is causing problems. If you replaced the head gasket, you could have the wrong one. If it's as bad as you say, a water pump won't do you much good.
Post a Followup
Subject:
