Re: 240 carburetor stud - re-die or replace?
Posted by K.B.-826 on November 03, 2004 at 19:42:15 from (209.163.43.8):
In Reply to: 240 carburetor stud - re-die or replace? posted by Dave D on November 03, 2004 at 16:17:55:
Part number 50705D at Case-IH. I would think that they would still be avalible, since that same stud was used in many of their carbs. Two studs would probably cost less than a die, and are a sure fix. If the first couple of threads on the stud are still good (good enough to get a nut or a die started), you sure could try to clean them up with a die of the same size, which would be 5/16" NF.
Post a Followup
Subject:
