Re: BN cooling problems - Part II
Posted by GENE B on November 04, 2004 at 04:40:55 from (66.43.221.243):
In Reply to: Re: BN cooling problems - Part II posted by ffolkes on November 03, 2004 at 21:46:16:
There are those who will rell you that you have to have a pressure cap to run a water pump. Around here there are several ones with pumps. I have put some on even on a C that mows a lot. Look at it this way for 92.00 for a rebuilt one with pulley as the new ones dont have a pulley and a new belt problem solved. Do you need the source where to get one? Send e-mail so we dont get in trouble with posting source.
Post a Followup
Subject:
