Posted by Chris NW Ind on April 03, 2009 at 16:13:53 from (64.136.26.226):
I posted a couple weeks ago that my Super M had lunched its pilot bearing and upper constant mesh gear. Well, I got all the parts I needed including a new clutch disk. 3 new bearings, 1 oil seal, good used input shaft and she is pulling again.
Also took care of a couple items since I had the opportunity. I ditched the belt pulley--it was only in the way--and I slid the rear hubs in to their narrowest position. One thing I found was than the right rim had slipped thru the clamps so I straightened that out. Never noticed it before, though I doubt I was the owner when it happened. Got the generator charging again; that regulator continues to give me fits.
The not-so-good news is that the trans still rumbles. The lower constant mesh gear has a bad spot. Can"t feel anything when I turn it by hand but I hear it. I"ll let it go and monitor to see if it gets worse.
Still, drives great and that motor sounds powerful. Last time I checked compression, it was around 135-140 psi on all 4 cylinders. Gave her a tune-up and new battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
