Re: H Hydraulic Fluid
Posted by Wayne Swenson on November 04, 2004 at 21:09:07 from (66.191.70.4):
In Reply to: H Hydraulic Fluid posted by GAC on November 04, 2004 at 16:25:40:
Original recommended oil was non-detergent 30 weight for summer use. I am still using this oil today because it is a heavier bodied oil than Hy-tran so will build more pressure. Less costly, too.
Hy-tran is an excellent product but is designed to best operate in systems with closer tolerances than the belly pump on your H.
Post a Followup
Subject:
