Re: how much off farmall H Block?
Posted by rustyfarmall on November 05, 2004 at 08:43:31 from (207.32.13.217):
In Reply to: how much off farmall H Block? posted by Nick Friend on November 05, 2004 at 08:18:28:
Absolutely no more than is necessary to achieve flatness. .025" to .050" on the head if necessary. If you go more that that amount, the head will be toast the next time it needs milled. Leave the block alone. If you really need to raise compression, look at pistons.
Post a Followup
Subject:
