Farmall A voltage regulator
Posted by Andrew Z on November 11, 2004 at 15:39:28 from (64.252.231.126):
I got a new regulator and there are three termnials on the side near the engine the old one had only 2 and of that only one was hooked up, the one that came from the generator. What wire goes where???
Thanks for the help!
Andrew
Post a Followup
Subject:
