Farmall Tractors Discussion Board
Re: Starting Trouble
Posted by The Red on November 19, 1999 at 06:59:08 from (206.246.187.2):
In Reply to: Starting Trouble posted by Jeff on November 19, 1999 at 06:02:29:
After you shut down, remove the voltage regulator cover and make sure the points are opening. If not, there is a tab and little spring. Slightly bend the tab to make more tension on the spring. Too much, though, the points won't close when running.
Post a Followup
: Re: Re: Starting Trouble
