Re: Adding a remote to a 826
Posted by K.B.-826 on November 13, 2004 at 20:21:22 from (209.163.43.31):
In Reply to: Adding a remote to a 826 posted by JW on November 13, 2004 at 16:37:51:
Aces has it right. Right now, you should have what I call a "closed end valve", meaning that oil can pass into it but not through to another valve. You need to buy a "open end valve" from any big 06, 26, 56, or 66 series tractor, install it where your valve is right now, then bolt your valve onto the left side of the new valve. If you get a valve from a junkyard, inspect the end of the spool sticking out the front. If it is pitted, it will leak and the whole thing is junk. The second lever could be a pain to install if the tractor has a cab.
Post a Followup
Subject:
