Re: Will the F12 head work on an F14?
Posted by Fawteen on November 16, 2004 at 16:42:17 from (65.99.190.125):
In Reply to: Will the F12 head work on an F14? posted by jonesy on November 16, 2004 at 14:43:59:
Yes, they are the same. There are slightly different versions having to do with the placement of the rocker arm supports and valve cover design, but as far as I know, they will all interchange.
Post a Followup
Subject:
