Farmall Tractors Discussion Board
Re: Starting Trouble
Posted by JED on November 19, 1999 at 18:31:31 from (207.115.48.68):
In Reply to: Starting Trouble posted by Jeff on November 19, 1999 at 06:02:29:
With the engine off and all the electrical accessories off, pull the + battery cable and put a ammeter/milli-ammeter in series with the battery and the cable. If there is any current draw you have a short. If there isn't you have a charging system problem or battery problem. Good Luck.
Post a Followup
: Re: Re: Starting Trouble
