Re: how to tell
Posted by Andy Martin on November 19, 2004 at 05:52:48 from (64.219.39.195):
In Reply to: how to tell posted by tracterman on November 18, 2004 at 14:25:58:
The proper cranking technique is to pull up only on the crank with your right hand, fingers only, which gives you a quarter turn pull. WHEN it kicks back, it will pull the crank out of your hand by straightening your fingers and you won't break your arm.
I've started a lot of tractors by crank and never been hurt. Occasionally I "windmill" one but that is always asking for trouble. If the tractor is hard to start, fix it or pull it to start, or crank it all the way around and let your friends sign the cast.
Post a Followup
Subject:
