Re: Block stamped with......
Posted by SAm in NS on November 21, 2004 at 04:35:12 from (24.138.19.172):
In Reply to: Block stamped with...... posted by AlbertafarmallA on November 20, 2004 at 22:48:52:
That's your prefix for your motor serial number. If you look on the left hand seat support plate you should have a serial number tag. The prefix for the number is FAA. The M just indicates that it is the motor serial number. By the way, if you compare your chassis serial number (under the seat) and your motor serial number they probably are not the same. Hope this helps, SAm in NS
Post a Followup
Subject:
