Re: 46 Farmall C
Posted by Peabody on November 22, 2004 at 08:48:14 from (68.117.176.46):
In Reply to: 46 Farmall C posted by 52 A Boy on November 22, 2004 at 08:33:32:
It was originally a 6 volt positive ground. Many have been converted in later years to 12 volt negative ground, accomplished by replacing the generator with a 12 volt alternator (with internal regulator), replacing the 6 volt battery with a 12 volt, installing a resistor in front of the coil on the hot wire from the battery, and replacing the 6 volt headlight bulbs with 12 volt bulbs. Oh yeah, and grounding the negative post of the battery to the tractor. Good luck on your project.
Post a Followup
Subject:
