Re: 6-volt blues
Posted by CNKS on November 22, 2004 at 09:23:32 from (207.178.96.213):
In Reply to: 6-volt blues posted by WSR MD on November 22, 2004 at 09:15:34:
The regulator is not built into an OEM generator. You are either supposed to have a cutout regulator mounted on the generator or a true voltage regulator mounted somewhere else -- mine has a cutout relay. It is always best to take the generator and regulator/cutout relay to the repair shop together, then the guy can adjust both of them together.
Post a Followup
Subject:
