Re: Farmall 400 or 450
Posted by Hayshaker5 on November 23, 2004 at 05:37:09 from (199.151.125.251):
In Reply to: Re: Farmall 400 or 450 posted by Hugh MacKay on November 23, 2004 at 02:20:14:
Dad had both models, a 400 and 450 Farmall. The 400 had a steering wheel with the exposed steel hub where the 450 had the "fancy" steering wheel.
Also there was a valve on the right side of the cowl on the 450 to switch from double to single acting hydraulic. Yes you could still have a belt pulley with the larger gas tank as our 400 had both.
Post a Followup
Subject:
