Re: Super A Hybrid???
Posted by Mr. Dan on November 23, 2004 at 18:41:17 from (216.12.192.75):
In Reply to: Re: Super A Hybrid??? posted by SAm in NS on November 23, 2004 at 15:16:08:
Uh... well, I don't SEE a water pump. There is a radiator hose neck bolted to the top, front, center of the block. At the bottom of that neck is a bracket which holds the fan shaft with a 2-slot pulley. The larger belt is driven by the drive pulley on the crankshaft. The smaller belt drives an alternator. I don't see any other possibilities for a water pump... just the direct-drive hydraulic pump.
Dan K
Post a Followup
Subject:
