Re: Removing an oil seal by the belly pump
Posted by RayA on November 25, 2004 at 20:07:47 from (69.150.134.157):
In Reply to: Removing an oil seal by the belly pump posted by dave westlund on November 25, 2004 at 18:59:51:
Hey Dave, I think you are talking about the tapered bolts that hold the coupling yokes together that drive the tranny? If so they are a beast. If I remember right I used the biggest wrench I could fit in there, a cheater bar and a sledge to get mine busted free. I think I also tried to put a bar behind them and tried to pry them out a little. A good amount of cussing every so often seemed to help also, haha. When you replace that seal you might look at the yoke that passes through it into the tranny. I replaced mine and I probably should have installed an Easy Sleeve that some of the guys have talked about on this forum as mine is leaking again. Hope this helps you out some.
Post a Followup
Subject:
