Re: IH 240 U - could I actually have (busted) powe
Posted by Dave D on November 28, 2004 at 05:33:15 from (4.233.179.131):
In Reply to: Re: IH 240 U - could I actually have (busted) powe posted by deano on November 27, 2004 at 17:47:46:
Deano, Sounds like we have identical tractors! Mine is yellow,
evidently was a state highway department unit for many years.
Rear tires are filled but mismatched - one turf type, one
construction type. At least it works...mostly.
As a matter of fact I added about 2 gals of hydraulic oil just
yesterday. In 2 months of ownership and intermittent loader
use, finally it failed to activate. Without any other info to go on,
I added hyd oil until the level became visible through the filler
hole -- my filler is high up on the right side of the tubular
loader frame, next to the Superior serial number plate. Is your
loader powered off a pump low in front of the grill? Mine is. I
have one leak on the high pressure fitting coming out of that
pump, and at least one other somewhere in the right main
hydraulic cylinder. It is always wet and the piston cleaner ring
just slides up and down on the piston.
Question: what is your Superior's hydraulic filter part number?
My filter assembly is kind of messed up, had been broken off
and was hanging from a rope when i bought it. I redrilled a
couple holes and managed to bolt it back onto the frame. It's
hoses are fine. I figure I should drain the system and change it
but don't know what filter element to get -- and don't even
know where to drain the loader hydraulic system!
Thanks, Dave D
Post a Followup
Subject:
