Re: has anyone every sand blasted a carb?
Posted by Theman on November 30, 2004 at 10:58:37 from (65.248.77.5):
In Reply to: has anyone every sand blasted a carb? posted by Chad from MI on November 30, 2004 at 04:50:31:
I sandblasted the carb on my H with great results. It really gets the crud out. Bead blasting (glass) is an even safer way to do it. I used #3 grit sand which is finer than usual and it doesn"t pit the cast iron or brass pieces as much. I also put masking tape on the mating (gasket) surfaces. Don"t worry about an accelerator pump on this carb. It doesn"t have one.
The nice thing about the H carb is that the passages that meter fuel are removable and come in a good carb kit. Take out the main and idle jets and you have a clear view of any place grit or scale could give any problems. I prefer to spray carb cleaner that comes in an aerosol can through all the holes in the two halves to flush out any dust and/or grit left on them. Once it dries off, paint some rust-inhibiting primer on them or your carb will turn iron-oxide red instead of Farmall red. I have seen some H carbs at shows that have been blasted then sprayed with clear laquer. That"s certainly a unique effect.
Post a Followup
Subject:
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
